I have gone full black a couple of times, under strong light the wood colour can still show up. Don't really like to do more than darken a board up a few shades really, it's more realistic that way.
Seal in with a thin coat of a drying oil, boiled linseed or Danish left to dry a couple of days. Stops the dye rub-off onto fingers. Redo it once in a while, the sealing oil can wear away and then the dye rub away as well.
I think the issue is it’s intended to be used on raw wood, and does not take as well on a factory guitar that may have already had some kind of light oiling or conditioning.
you can stain raw rosewood black, give a light rub down with 0000wire wool and never get black fingers at all.
a coat of oil after won’t hurt at all though.
Instagram
so leather dye is the way to go?
