Fishman GII outboard preamp £40
Fishman GII outboard preamp for acoustic instruments. Excellent condition, with box, just surplus to needs. I've been using this with various piezo acoustics and mandolin, always works and sounds great.
Self explanatory preamp with boost/cut shelving style tone controls.
Sounds good, as usual for Fishman, ideal for a light, simple outboard option.
Happy to arrange postage or collection, drop me a line for more info.
Specs:
Nominal Input Level: -20 dBV
Input Overload (20 Hz to 20 kHz): +8 dBV
Input Impedance: 10 MOhm
Output Impedance: Less than 3.5 kOhm
Output Level: -20 dBV with input gain control at minimum position
-8 dBV with input gain control at maximum position
THD: .01 at 1 kHz, -10dBV input, -4 dBV output
Signal to Noise Ratio: 91 dB (A weighted, -10 dBV input, -4 dBV output)
Bass Control Range: ± 11dB at 60 Hz ± 3 dB at 350 Hz
Treble Control Range: ± 11dB at 10 kHz ± 3 dB at 2.4 kHz
Current Drain: Less than .4 mA
Power Supply: 9V alkaline battery (estimated 1400 hours continuous use) Regulated 9V AC Adapter
Tip = negative 9 V
