Reverb - marshal dsl40r 2018
fastonebazfastonebaz Frets: 4106
The reverb on my 2018 dsl40r is so subtle that even on max of 10 I can't really detect any reverb.   Other amps with on-board reverb are so obviously reverby that getting near to 10 makes it unusable.  Anyone else got this same amp?  What's yours like?
Thinking I might have a problem with mine.
  • ICBMICBM Frets: 72414
    edited May 2018
    Yes, probably - from memory the reverb is pretty obvious on them.
    It’s a digital reverb on these so it won’t be the usual spring-reverb problem of a broken wire in the tank. I can’t remember if the reverb module is on a separate PCB, but if it is then it could possibly be the jumper connector to the main board making a poor contact - but if not that, it’s most likely a faulty reverb module.
  • fastonebazfastonebaz Frets: 4106
    Sending it back under warranty for repair.
