On/off switch on amp or wall?
martmart Frets: 5205
I’ve recently acquired an amp with the on/off switch inconveniently located round the back. Is there any risk to the amp if I just switch it on and off by flicking the switch on the mains socket (which is much easier to get at) rather than using the switch on the amp itself?
  • ICBMICBM Frets: 72453
    No, it’s exactly the same.
  • martmart Frets: 5205
    Thanks. That’s exactly what I was hoping to hear. :)
  • prowlaprowla Frets: 4930
    The only potential issue with doing it at the wall is if you have other kit running from that same socket, so you may get spurious bumps, whistles, etc. (I have a Minitaur and it screams when it's powered off!)
  • fandangofandango Frets: 2204
    edited May 2018
    Wot, like Bruce Dickenson or a 2 yo that’s been fed peas?
    Edit: sorry couldnt resist this train of thought
    edited May 2018
    I have a Princeton, and the switch is round the back. Use the amp switch because wall socket has other stuff.
    A banshee that's tripped over a crucifix!
