Pedalboard Splitter
webrthomsonwebrthomson Frets: 1031
Any recommendations for a pedal board splitter - I need to split the signal on my board to my new noise gate - so literally one in two out:
So far all I can find is this one on reverb.com:
Or the JHS ones at £80
Any suggestions?
Thanks!
  • hotpickupshotpickups Frets: 1822
    Call bright onion. James's will sort you out I'm sure :)
  • jamiexsilverjamiexsilver Frets: 404
    2nd vote for bright onion.
  • fandangofandango Frets: 2204
    edited May 2018
    I'd read that Lehle products are pretty good, but no personal experience.
    http://lehle.com/EN/Splitter
  • Rowby1Rowby1 Frets: 1279
    Bright Onion, definitely worth a look.
  • robinbowesrobinbowes Frets: 3042
    For that specific purpose, I *think* you would get away with a Y-cable, ie. literally just send the same signal to two pedals. You could also do this with three jack sockets in a small enclosure. Worth trying before spending a load on a more expensive device.
    R.
  • SporkySporky Frets: 28198
    R.
    If the split is after an always-on pedal or something with buffered bypass you are probably right.
    R.
    Probably. ;)
  • webrthomsonwebrthomson Frets: 1031
    Right Bright Onion it is then :)
    Thanks!
    R.
    Yeah thats one of the reasons I asked I was unsure :)
    edited May 2018
    If I were doing this for myself, I'd build a simple buffer in a small box and add an extra output. If you're not able to self-build then Bright Onion is probably your best bet.
    R.
