Poor man's Avantone Mixcube?
Can anyone recommend an alternative passive reference speaker? Or is there nothing else like it?
Thanks!
  • Winny_PoohWinny_Pooh Frets: 7771
    edited May 2018
    What do you mix on ATM? I built a pair of mixcubes but its tres hassle.
  • blobbblobb Frets: 2975
    edited May 2018
    https://www.juno.co.uk/products/triple-p-designs-pyramid-studio-monitors-pair/477620-01/
    alternatively, the avantone headphones have a 'mixcube' setting - as well as full range and mono.
    Feelin' Reelin' & Squeelin'
    In theory any cheap boom box would do a similar job but the Avantone's are worth the expense if you need that sort of thing.
    They are, imho, strictly a quick reference check for 'bandwidth limited' playback devices to make sure you don't have any crazy frequencies poking out.
    I use some old Denon 2 way monitors for this- I took them off an old component system.
    I also use a Sonos Play 5 as well as my proper monitors.
  • goldtopgoldtop Frets: 6160
    @Winny_Pooh - what drivers did you use? Somewhere out there is a forum thread (not on tFB) that went into great detail about building them. ISTR a sound engineer had sourced the correct driver and - as it happened - Maplin (remember them?) stocked those. I've got a pair (drivers) somewhere in the To Do Projects box.
    But cheap hifi is no longer so prevalent. People listen on phones, soundbars, 5.1 systems, Sonos/etc boxes, bluetooth speakers - all with different characteristics. With so many non-stereo and generally weird systems, I'm not sure that the mixcube recipe is so relevant.
  • BusheySiBusheySi Frets: 64
    Rokit RP6 G2.
    There's no chance I'd be able to build a speaker!
    Rokit RP6 G2.
    Why are you looking at Avantones?
    @goldtop a pair of Visatons as used in the littlepapercones mix cubes.
    As for the OP you might find a set of JBL Duets handy. They are not as revealing as mixcubes but useful for balancing.
    They look ace.
    edited May 2018
    Rokit RP6 G2.
    I'd upgrade those before buying more speakers. I used to have the R8s and could never really get them to work. I now use a set of Neumann KH120s and they are a delight, even for normal listening.
    Sweet. A bit ironic that they look so much better than they (are meant to) sound! :)
    It's funny that, my wife was definitely expecting something more refined than the Q acoustics in the living room when I plugged these in haha
  • RamirezRamirez Frets: 11
    I have to disagree here. The thing with Auratones/Mixcubes is not that they sound bad - they don't in fact. It's just that there isn't much in the way of treble or low end. What the lack of treble and bass does is highlight the crucial midrange, and the Auratones/Mixcubes have exceptionally low distortion levels and time-domain performance, so that all important mid-range is delivered very clearly and accurately. This makes them very well suited to balancing important elements such as vocals as you're not distracted by the ear-candy at the frequency extremes.
    In my mind they don't do the same job as a cheap/grotbox speaker, although its often perceived that they do.
    Not the model boy of the village
  • stevebsteveb Frets: 42
    Behringer behritone. Not sure if theyre discontinued tho
    Yep, discontinued and rare.
