SOLD: Danplifier Dragon - 30-watt hand-wired amp head (JCM 800/Friedman Dirty Shirley)
imalrightjackimalrightjack Frets: 3760
edited June 2018 in Amps £
This is a hand-wired amp based on the Marshall JCM800/Friedman Dirty Shirley. It's an EL34 (it can also run 6L6s - and it's cathode-biased so does not require biasing) powered small head with a few additions.
Treble, middle, bass, gain and master volume. It also has a second footswitchable master volume you can use to boost it.
The three toggle switches on the front are the Friedman C45 mod, three position gain switch and a fat switch.
8ohm and 16ohm outputs. FX loop.
W50cm x D20cm x H20cm.
It also has a matching active footswitch.
Amp is in excellent condition (the labels peel off). Newly valved.
Collection from Penrith or Carlisle. Will post for £25.
£450.
Will consider trades for guitars with cash in your direction.
Trading feedback info here
My band, Red For Dissent
