Any ideas how I'd run a Superego Plus in parallel to the post-amp/cab FX of the Kemper?
I don't want the delay or reverb (or X) to run through the Superego and I want to merge the Superego sound back into the signal in parallel with the KPA FX.
Any advice would be welcome, thank you! Also interested in hearing how you guys run a Superego with regular setups, ta!
Cheers
