@kennedydream1980 the HT dual did not occur to me. I will have a listen to some demos.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Take your guitar, plug in, and concentrate on the songs.
Eqd Speaker Cranker clone
Not available new now, but you should be able to find one second hand fairly easily.
Matchless Hotbox - again not cheap, and they're huge but sound lovely.
(Clean I never liked the dirt).
Wampler Black 65 wasn't bad either to be honest
All the openess, chime etc is very open to interpretation. Factor in which type of PA you are going into, the speakers etc etc and you are further removed
If you want a valve amp sound you probably want to play through a valve amp
They can be used as a pedal in front of an amp, a preamp run into the FX return of a tube amp, or DI as they have a cab sim option too. All are two channel and can be had for less than £100 new.
