Cut off the mains plug and fit a 1/4". Instant (roughly) 16-ohm load .
Yeah, I can give the guy chapter and verse on how to build one but he seems very reluctant to do so IC.
Will have a gander at Rats Timmy.
Cheers each.
Dave.
http://ofeuillerat.free.fr/otherdocs.html
basically uses the coiled spring heater element to an old electric fire as the load for running a valve head down to line level .
It was Allan that designed the rocktron juice extractor, too ( except he didn't like it).
a kettle is a bulky thing so would want to take element out & rehouse (small wooden box). so am wondering what other things i need to pay attention to. screen with foil? earth wire?
That would be a fire risk with anything more than a very low-power amp. The point of using a kettle or a heater is that it's purposely designed to get hot, safely.
This is not theoretical, by the way - when I've worked on high-power amps like Marshall Majors and Hiwatt 400s I rigged up loads like this, since no commercial attenuator/load will handle the full power... especially not the Hiwatt, both the ones I've worked on produced around 450W clean and over 700W fully overdriven.
just seems a funny thing to have a kettle wired up the the amp. looks a bit odd. but if you think best to leave as is, i will.
https://www.vishay.com/docs/50020/rssd.pdf I made up a good 1/2 doz welded ally boxes of 2mm metal using the 450W RSSD 4ox 370mm adjustable resistors. Two 4r7 in series then the band was tweaked to get a very precise 8 Ohm load as read on a special 4 wire "low Ohms" meter.
The high power handling and precision is needed for test purposes but is a very expensive overkill for general workshop testing or practice. They do run out very expensive mind, even sans my time!
The kettle scenario is an interesting one! Checking my Russell Hobs I see it is rated 2400 at 240 V so a "burning" resistance of 10 Ohms, near enough for jazz for both 8 and 16 Ohm amp taps. However, when I measure is stone cold it reads 25 Ohms and of course that will only get higher as it heats up.
25R is of course fine as a "safety" load for biasing etc but I would not like to drive a valve amp to clipping on such a high resistance, not even on a 16R tap.
Ah! Jusfort! I have a mains consumption tester somewhere, will check the kettle kW.
"O'il be beck"!
Dave.
It’s fine anyway, it’s well within the natural impedance range of a 16-ohm speaker cab at a bit higher than 1KHz.
I thought that looked off at first glance, but didn't want to say anything because I wasn't sure.
This means that the 'average' impedance - especially for distorted sounds which include more high-frequency content - is higher than the nominal impedance, so if you're using a resistive load (which does not change with frequency) it's usually better to pick a value slightly higher than the nominal if you're trying to duplicate the load on the amp under normal 'speaker' conditions. Somewhere between the nominal and double it will be about right, so a resistance of 24 ohms for a 16-ohm amp is pretty much perfect.
I have certainly never had any trouble testing amps into these sorts of loads, even running at the maximum continuous distorted power for long periods.
