Seymour Duncan Woody XL - Updated with short review plus Jam up Acoustic Pack
guitarfishbayguitarfishbay Frets: 7962
edited June 2014 in Acoustics
I need a solution for an acoustic guitar that won't require any modifications.  Keeping the budget under £100, is there any better option than the Woody XL?
It will be used to amplify my guitar at open mic gigs as and when necessary over the next month or so.
  • crunchmancrunchman Frets: 11461
    I've seen K&K Pure Mini for £90ish without a volume control.  You'd probably need to pay extra for fitting though.
  • BigLicks67BigLicks67 Frets: 768
    I can't really offer any new suggestions, but I would suggest you avoid the Fishman Neo D. I had one and it was awful. (single coil version).
  • I wound up ordering the Woody XL.  I will be doing some open mic stuff at the end of next week so didn't want to wait any longer as I want time to test it and make sure it all works ahead of time.  Long term if I end up doing a lot of acoustic stuff I will buy an electro acoustic that I pick based on how good it sounds plugged in but for now I just need to have an option for plugging in to the PA.
    I will report back once I've had some time with it!
  • menamestommenamestom Frets: 4723
    I have the Humbucker version, it's very good, although this is of no use now to guitarfishbay!  They say the humbucker version is a little fatter than the SC, as you would expect, but I wouldn't want a pickup thinner than the HB version.
    I'm sure the woody will be nice, a mate had one and it was perfectly usable in most situations, but sometimes was nothing more than passable direct to a PA.  But that's true of most magnetic, passive pickups.
  • thomasw88thomasw88 Frets: 2328
    2nd lr baggs m1a is superb.
    edited June 2014
    Ok I have had the Duncan Woody XL for a short while now and here is what I think.
    Pros:
    - Comes in a nice carry bag with draw string.  It is a bit big to fit in my Hiscox case internal storage section along with my clip on tuner, spare strings, and winder/cutter.  But for me this isn't an issue as I take a bag with me for reasons discussed later on.
    - Very easy to fit, no marks left on your guitar, non permanent.
    - Cable is pretty long and seems quite sturdy
    Negatives:
    - Tone is lacklustre at best!  Sounds like an electric guitar pickup, which isn't that surprising really.
    - Output is pretty low.
    - Cable is hard wired in, which for people who aren't able to solder means what you see is what you get.  I think a sensible mod might be to replace the end with a female jack but cut off a lot of the excess.
    The balance was way off when I first fitted it.  I'm pretty glad I went for the adjustable model in respect of this, and in reality it only took a few minutes to get the string balance the way I wanted it.  I wound up screwing down the allen pole pieces on the plain strings and increasing them slightly on the lowest two wound strings.
    Tonally my first impression was disappointment.  I didn't expect much, but even then I still felt it was a 'get out of jail' sound at best.  I experimented and discovered that with an EQ pedal I could get closer to an acoustic tone again, by cutting bass and low mids and boosting presence.
    I came to the conclusion that I needed a new solution as taking an EQ pedal and a power supply is not really a good choice for open mic nights IMO, it is way better to work from batteries when you don't know what the plug situation will be and have to do a quick turnaround.  I've since sold the EQ pedal on here because I never use it for electric guitar anymore!
    I settled on using an iPad, Line 6 Sonic Port, Jam Up Pro, and the Acoustic Pack.  The Acoustic Imaging model with some dreadnaught blended in with the dry signal sounded pretty decent.  I also picked up the pack that has the LA2A compressor in it, just to even things out a bit between the strumming and single note stuff.  It wasn't doing a lot but I felt like it was helping when I tested it at home.
    Last night I tried the iPad/Jamup setup live for the first time and our drummer who was in the audience thought it sounded pretty good.  My only concern was that there was a little latency that was noticeable to me as the player but since there are no stage monitors I could only really hear the amplified acoustic sound when it was me playing on my own (we do these sets with two guitars, two voices - the other guitarist sings harmonies and the singer just sings).  FWIW I did have it on ultra low latency mode.  I'll have to have a look in to it!
    Overall it seems like an ideal solution for me, for now.  No permanent changes to my guitar and the iPad battery lasts bloody ages plus I can always see what percentage I'm on.
    (First post had too many characters)
    This guy has done a video using a piezo pickup on a Yamaha through Jam UP's Acoustic Imaging model.
    IMO the Woody has such low o/p that an external preamp is required. By the time you've paid for the Woody and a preamp you might just as well have bought another guitar with a decent o/p. That's how I ended up with an SBF-80 Washburn.
    I did think about just buying another guitar but I already had the iPad and was already going to buy a Sonic Port and Jam UP anyway.  In light of this I've only spent an additional £14 on two packs for Jam UP, which is way cheaper than a pre-amp or another guitar.  I thought it actually sounded better than my bandmate's Yamaha electro too.
  • BidleyBidley Frets: 2933
    Phil is right, you'll need a preamp of some sort with piezo pickups, otherwise you'll have very low output and that horrible 'quack;. But it sounds like you know this :)
    yes and a radial PZ-Pre costs as much as a guitar!
    Yep, not debating that.  I'm just saying that for £14 on top of what I already owned I got a usable result for my purposes.
    What I've not mentioned is that I play in lower tunings, currently D but we are experimenting going to C# to allow some new material to be sung within the vocalist's range.  I already use 13s and find them a bit loose, so I'll be moving to 14s.  This will mean I'll be taking the guitar to a tech to get the bridge properly intonated, as I can't do that work myself.  So not only would I have to factor the cost of a new guitar, I'd have to factor in the cost of a set up too.  For the time being I'd rather just stick with what I own.
    Good stuff. I posted it more for the purpose of the thread and reference than anything else :)
    It's worth bearing in mind the humble capo for tuning-to-help-the-singer-out purposes too. Although my voice suits a brighter guitar tone more than most. And lower/drop tunings do sound the tits on acoustic!
