All 5 positions....
HootsmonHootsmon Frets: 15999
edited June 2018 in Guitar
tell us about your favourite Strat switch positions and the ones you don't use
and who ( famous dudes) uses what position for great legendary Strat tones on record and live?
position 1 = switch closest to bridge
tae be or not tae be
«134
  • guitars4youguitars4you Frets: 14455
    looking at the OP heading I was hoping to learn something new and try it tonight
    4reaction image LOL 0reaction image Wow! 2reaction image Wisdom
    Seriously I'm neck only most of the time, then 2 or 4 at times
    Never use 3 and only the bridge on rare occassions
  • SporkySporky Frets: 28758
    When I had a strat (well, a G&L Legacy) I liked 3 best.
    Then I put humbuckers in it and liked it more.
  • richardhomerrichardhomer Frets: 24852
    All except Middle/Neck generally. On a ‘good’ Strat they all sound good - including the bridge.
  • HootsmonHootsmon Frets: 15999
    Do peeps struggle with the bridge PUP and are most Strats shy of a tone control for the bridge?
  • munckeemunckee Frets: 12438
    Use them all neck/middle for cleaner than clean type sound middle for 60s pop sounds, bridge/middle for lots, bridge for surf and neck for anything.
  • strat84strat84 Frets: 322
     I only used to use neck, neck/middle and middle/bridge.. I used to hate the middle and thought it was really unforgiving but I find it one of the best now. Great for funk or a bluesy ryhthm or lead, clean or overdriven.
     Live, I think SRV used the neck pickup for Pride & Joy but the album version to my ears is mostly middle then switching to the neck right at the end.
  • LestratcasterLestratcaster Frets: 1096
    Second position (neck/middle together) sounds nicest on mine for cleans. Not overawed by the bridge dirty sound atm though.
  • BrizeBrize Frets: 5636
    I find that some Strats sound better than others in different positions. For example, I've got one Strat that sounds great on the bridge but a bit meh on the neck, while another sounds great in position 2 but the bridge pickup on its own is way too harsh.
  • poopotpoopot Frets: 9099
    I’m going to throw a spanner in the works and say that I use all “9” positions on mine ;)
  • jpfampsjpfamps Frets: 2734
    I have a 3 way, and mainly use the middle position (which for me is 2).
    SRV would often change pickups mid lick (!).
    I’ve found the same but the one I have now - and a vintage one I no longer own - sound/sounded genuinely brilliant in every position.
    easy mod to wire the bridge pick-up to work on the tone pot with the middle p/up - Or move middle to work with neck tone control and the bridge has its own tone pot - Or Eric Johnson style with tone neck + tone bridge and no tone middle - various options
    it is useful to have some tone pot on the bridge to soften any spikey highs
    But on a good Strat, with good pots the vol pot provides so much expression - small tweaks on the vol pot dial subtle tonal variations ,especially on gain settings - So much so that it should be called an expression pot and not a volume pot
    thanks Guys  :)
  • AlnicoAlnico Frets: 4616
    My Strat switch has been wired differently.
    1 - Bridge
    2 - Bridge and Neck in parallel
    3 - Neck
    4 - Neck and Middle in parallel
    5 - Middle
    This puts my most used positions right next to each other and also gives me a new one which sounds excellent.
  • jimmyguitarjimmyguitar Frets: 2474
    Even though I love the inbetween sounds..at gigs it tends to be middle pickup for funky, rhythm stuff, neck for bluesy breakdowns and bridge for powerchord/lead work.
  • flying_pieflying_pie Frets: 1818
    Yngwie Malmsteen will often start a bend on the neck pickup and instantaneously switch to the bridge to really open it up
  • ICBMICBM Frets: 72716
    edited June 2018
    I use all of them, although the single-pickup positions work better for me than the in-between ones.
    Some of my favourite player's sounds on the five positions are...
    1 Ritchie Blackmore
    2 Mark Knopfler
    3 Lenny Kaye
    4 John Frusciante
    5 David Gilmour
    ^ RB on pos 1 yet he gets that warm Strat tone?
