The problem, when talking about them, is that there is limited published spec, and the necks changed during different periods even within the 90s. So it's hard to state exactly what a neck will be like.
There are some general principles though:
- the profile tends to be a c shape, but can vary from skinny to a bit fatter
- 24 fretters tend to be mahogany and 22 fretters maple (although pretty much all the bolt ons will be maple)
- most Berlin and Vienna fingerboards will be ebony, New Yorks and LAs can be maple, rosewood, ebony depending on the variation
- early 91/92 models may not have a volute and this indicates it may be hand carved, mid 92 onwards will have a volute
Do you a specific example you're curious about? A model and year may enable a slightly more educated guess...
The '92 Pro V, the '95 Plus and the LA have very similarly shaped necks. Fairly slim C shapes, not too narrow and very comfortable. The '92 Deluxe has a slightly narrower, more D shaped neck which is comfortable and fast but can be a bit tight for clean picking. The '96 Pro V has a chunkier neck than the others, C shape, not huge but more of a handful. Again, it's very comfortable and fast.
I heard that the early guitars had their necks shaped by Patrick and the shaping was based on an old Gibson SG that was his favourite neck. Not sure how true that is.
