It's not a '71 since it has the '72 body shape, but if he's dated it from the pot codes then it could be a '72.
It's very likely that it's genuine and original for that reason though - the later body shape doesn't get copied. The pickguard has been changed unless it's a '75 or later since it would have been white originally. The knobs may also have been changed since they're unusually shiny and un-pitted compared to the rest of it, and the 70s plating usually flakes badly (and dangerously, it's razor-sharp).
It seems like a lot of money for a 70s-shape Tele anyway though.
This.
I used to own a ‘71 that was the ‘correct’ shape. It was heavy, with a very thick finish and fret slots which were too narrow for the (original) fret tangs - which meant even with the truss rod fully slackened, no further relief could be added.
A used CS Tele is likely to be a better guitar in every respect - and half the price....
Trading feedback: http://www.thefretboard.co.uk/discussion/72424/
Can you afford it?
How would you feel if you went back tomorrow and it was sold?
The answers to these questions will tell you whether to get it.
IMHO the only reason to buy a 70's Fender is because it will go up in value-- so it has to be pretty much original and not too much of a stinker.
If you want something to actually play then a modern CS is a better bet.
No notch at the outer end of the pocket and the inside edge of the curve parallel with the 17th fret rather than just above it... hence it's the '72 shape.
This is the earlier shape -
http://guitarsandaudio.com/extras/2010GASpics/Fender/66Telecaster/66Telecty3.JPG
Yes...
My guess given the claimed date is that it's an early-ish '72 with '71 dated pots, with a replaced pickguard with or without humbucker rout. What telehack says about the apparent lack of visible stamps on the bridge is correct too, unless they're just not clear in the pic. (Edit - they're there, you can see them in the new pic if you enlarge it.)
Also, if you blow the pic up to full size you can see that the switch screws are slot-head not Philips, so that's almost certainly been replaced too. The control plate screw at the tone knob end is also missing and the plate doesn't align with the hole in the wood, which may either mean that the plate isn't original or that it's had to be moved slightly to fit the pickguard.
It's actually amazing what you can work out from just one fairly low-res pic, in fact! But to be sure, you would have to see it - two minutes with a screwdriver in hand would tell you nearly everything. I would *definitely* want to see under both the control plate and the pickguard.
I still think it's overpriced no matter what though...
I do like the idea of a birth year guitar but not at that price.
