Do you prefer pentode or triode?
fastonebazfastonebaz Frets: 4134
 Which sound do you prefer on your Marshall amp pentode or triode?  Can you describe the difference in how it sounds to you?
I realised mine's always been in triode, I forgot about it tbh.  Penny for your thoughts....
  • revsorgrevsorg Frets: 885
    I know it's not a Marshall so I don't know if this will help at all but my Rivera M60 runs on a pair of EL34 valves and has a triode/pentode switch round the back.  Triode is dull, pentode makes me feel like a guitar god - harsher, louder and more alive.
  • Guitar_SlingerGuitar_Slinger Frets: 1489
    edited July 2018
    When you ask "prefer"... I've got a JCM900 combo which is run in low power (triode) mode at 25w.
     I hadn't thought of it as pentiode and triode, but as not wanting to play in a "you're OK but your guitarist's too loud" pub band.
    I prefer pentagrams
  • ICBMICBM Frets: 72642
    Pentode, always. Triode sounds crap - muddy and lifeless. (It can also increase hum.)
    If it’s too loud in pentode, just turn the master volume down slightly.
  • jpfampsjpfamps Frets: 2734
    Pentode.
    Like, dur, why didn't I think of that?  Seriously, I turned up at a rehearsal room years ago, put it at 25W, rocked out and have left the amp in triode ever since without thinking about trying it the other way.
    Next outing, I'll switch to pentode after a few songs and compare the difference.  Thanks for the (stating the obvious) tip.
  • RiftAmpsRiftAmps Frets: 3180
    'Triode' sounds crap in a circuit designed for pentodes - which is where you'd most likely hear it. Design a circuit around triodes properly though and they sound just as good
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • ChuckManualChuckManual Frets: 692
    Out of interest; What are the best examples of this?
    Not much of the gear, even less idea.
  • fastonebazfastonebaz Frets: 4134
    Doh. That's exactly what I did
    Many, many old radio and HiFi circuits. Most valve datasheets for power pentodes show suggested operating conditions for triode mode, yet modern designers seem to ignore them (admittedly because the Pentode/Triode switch is usually an afterthought).
    My PR6 uses a pair of 6V6s configured as triodes running in push-pull, with optimised conditions to do so. You get 6w without SE hum and no perceivable loss in tone (other than that associated with lower volumes).
    Rift Amplification
    www.riftamps.co.uk
    I can't find any videos of the PR6 on YouTube - but, from your description, I'm imagining a pleasantly warm and easily naturally compressed tone from two 6V6's only putting out six watts...? Or is my understanding of these things woefully poor?
  • DJH83004DJH83004 Frets: 196
    +1 for RiftAmp's comments, the characteristics of the valve change significantly when switching to triode operation and have to be taken into account in the design, e.g. output impedance, open loop gain (hence amount of NFB), input sensitivity, lower distortion etc.have to be catered for, so simply putting in a switch to connect the screen grid to anode, results in the woolly sound that you actually hear.
  • SporkySporky Frets: 28698
    Pentodes are harder to push over.
    Had a brief experiment at home levels between triode and pentode and I think I'm starting to hear the slight woolliness in the triode that has been mentioned above.  Will give it a thorough blasting at rehearsal next week!
    Don't know about guitar amps, but some triode hifi amps can sound pretty lush.
  • TA22GTTA22GT Frets: 362
    I've never played any guitar amp that sounds good in triode.
    My amp can do it but I can't understand why they would want to make a crap sound a feature!
  • PhilKingPhilKing Frets: 1493
    I always find that triode mode loses the attack and softens the response of the amp.  Not a sound that I really want.
  • ecc83ecc83 Frets: 1639
    edited July 2018
    Funny story. The first Artisan 15s and 30s switched to SE for the lower power option i.e. still pentode but it transpired that someone (in the states?) claimed they had a patent on the circuit. Since B's were then just getting started and an international legal battle was not on,  the circuit was modified to triode operation.
    Not ideal as many above have said but what can yer do with yer nuts in a vice?
    The HT-5/HT-1 is of course triode from the go-get.
    Dave.
    @ICBM does the sensitivity switch on the back of my Sound City 50+ chance between pentode/triode? I know theres a difference in volume but can't remember why (I tell people who ask that it's an attenuator).
    I used to frequent PlexiPalace and a Sound City fan site years ago, but have forgotten much of what I've read. I blame old age.
    No, it's just a basic volume cut before the power amp. Technically it *is* an attenuator - of the signal level - but not what most people would call an attenuator now .
