Stratocaster Bridge plate string breakage
My mim standard stratocaster just broke a fairly new b string at the bridge plate.
What's the best way cure string breakages that's caused from the string rubbing on the bridge plate?
I can see a little notch in the metal of my bridge plate where the string comes out from the trem block.
Do I file it flat? Change the plate? Put some sort of rubber over the string which goes over the plate?
