Domestic air conditioning
Want a couple of units for bedrooms.
What should I be looking for, and how much should I expect to pay?
    edited July 2018
    How big are the bedrooms? I've had one for years and for normal summers they are OK - mine is probably knackered. An average bedroom will cost £300+ and you will need a window to stick the hose out of. You can buy an external wall mount job for £650+ plus installation.
    This will give you an idea:
    August is forecast to be wet and cooler ...
  • roundthebendroundthebend Frets: 1137
    Our rooms are fairly small, about 3.5m x 3.0m.
  • SporkySporky Frets: 28384
    Portables are noisy.
    The one I got for my workshop was about £1500 (including installation) and £110 a year in servicing, but it's near silent and much more effective than the £300 portable in the bedroom. The workshop is 7m x 4m though so you'd be OK with a smaller, cheaper unit per room, or a central heat exchanger and separate wall units.
    Our next house will be air cooled and heated.
  • NiteflyNitefly Frets: 4920
    We just got a ceiling fan from B&Q, installed in place of the existing light fitting about 5 years ago.  I think it as £49.
  • rocktronrocktron Frets: 806
    edited July 2018
    The company I work for hired floor-standing portable air conditioners when our office building cooling system broke down. They are made by:-
    AMCOR
    DiET
    CHALLENGE 8000 BTU
    Unfortunately, I do not have the model numbers.
    The above are quite powerful and very effective at cooling. However, you would need to fabricate an opening in a window for the exhaust hose. Most of these units are supplied with an exhaust hose adaptor for windows.
