Rendering a pickup screw ‘threadless’ (intentionally)
jaymenonjaymenon Frets: 820
edited July 2018 in Making & Modding
I wonder- how would I smooth off the threads (i.e. render ‘threadless’) the top 2-3 mm of a screw - the bit just adjacent to the dome head?
I ask since I have a set of rather expensive pickups that I need to mount to wood on a Warmoth strat body. The holes in the Warmoth body are just the right size for the pickup screws - but since the thread on the pickups is perfect for the screw, I will wind up destroying the thread on the pickup base.
If I can somehow make the most proximal part of the screw thread less (I.e. like a 3/4 threaded screw), this would allow preservation of the thread on the pickup base and possible future mounting to a scratch plate...
I suppose I could do the paper on a toothpick with superglue thing to make the holes on the wood body smaller - and use smaller screws. But  it’ll take a lot of paper a lot of superglue ...
Expert opinions most appreciated...
  • FunkfingersFunkfingers Frets: 14474
    Why not use a wood screw that is smaller than the thread hole in the baseplate then, take up the slack with a grommet?
    This is what Charvel does on the San Dimas. This way, the only part that might require physical alteration is the grommet.
  • jaymenonjaymenon Frets: 820
    Please explain funkfingers - I didn’t understand that.
    I have some 2.2mm thick screws that pass cleanly through the pickup holes, but the holes in the guitar body are too big - and the 2.2mm screws don’t ‘bite’
    I could try making the holes in the body smaller with paper and superglue...?
  • CorvusCorvus Frets: 2926
    Mount screw in drill chuck; mount drill in a hazardous non H&S-approved manner with clamps, vice or whatever bodgery required; turn on drill, use a file against the threads you want gone. Hold the file with a hand at either end.
    A drop of oil wouldn't hurt as well. Wear safety specs/goggles/etc. Don't stand directly in line with the file so bits are fired at your face.
    Or similar in a drill press.
    I should add, the screw will be weakened quite a bit doing this, so do the least thread removal needed, drill pilot holes, use candlewax or soap and go easy on it with the screwdriver.
    Kinman pickups take a conventional fender style screw which I think is 6-32UNC ( from what I understand the closest equivalent is M3.5).
    I wonder if something like this would work if the top part passes freely through the holes in the pickup base?
    the 3.5mm x 20mm 3/4 threaded screws measure:
    3.1mm minor diameter
    3.35mm major diameter
    and 3.1mm in the unthreaded smooth top part near the dome head.
    https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F182423982996
    And thanks Corvus and Funkfingers for your help...!
    Other options:
    - fill the 3mm screw holes with wood filler and re-drill smaller holes?
    - use a small rawl plug in the existing holes so I can use smaller screws
    What a nuisance - I didn’t realise how much of a hassle this would be...
  • FX_MunkeeFX_Munkee Frets: 2478
    I've done this for body mounting before. The screw threads into a bar I set into the bottom of the pickup cavity and spins freely in the pickup ears. This way you can get adjustable height body mounting.
    @Corvus method is correct but in reality you only have to remove a tiny bit of thread and on these screws it's so fine you can do it by running a file gently round the top bit.
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
    One possible solution -  i’ll find out tomorrow if it’s worked.
    I rolled up strips of paper (over a toothpick) then inserted them into the 3mm screw holes at the bottom of the pickup cavities.
    Then a couple of drops of Superglue.
    Tomorrow hopefully I’ll be able to screw in a 2.4mm diameter screw that will hold the pickups in place...
    https://imgur.com/a/mOXvGPZ
    edited July 2018
    All done and dusted.
     One problem on a Warmoth chambered body though -  passing the pick up wires down the routs for them  is a right pain. Sometimes I wonder if that channel makes contact with some of the ‘chambers‘ (It is a chambered body).
    https://imgur.com/a/ft3oP8l
    https://i.imgur.com/b7wm4lw.jpg
