Though it might be a bit cheap and nasty but it's actually really well thought out and I'm an ex-design engineer so I'm usually the first to point out where they've cut corners.
We use expensive ones at work (Gaggia etc.) and TBH they're not as well made or designed.
Admittedly the Delonghi doesn't have all the bells and whistles (ie no scrolling LED display etc.) but it makes espresso like a good un There's not a lot to play with in terms of making different brews, just the controls to set your prefered strength and volume (and grind size which is set once).
I clean it about once every 2 months, which is no great chore as it's just so well designed inside (did I mention that?), you just unclip the main "block" which does all the work and give it a soak/rinse.
Editted to add: Do it! It's one of the best things I ever bought for the house and gets a lot of use. Be warned though, you'll never go back to "lesser" home coffee
I use a Moka pot, or French press/cafetiere so no steam wand available.
I'll try your technique, it sounds easier.
