Hi all,
Got a series 2 50w rectifier recently and looking to get some new valves.
I called Watford Valves and spoke to Derek about getting a nice crunchy sound more focused midrange and highlighted this kit -
https://www.watfordvalves.com/product_detail.asp?id=2897Anyone had experience with 5881's in the power section and the selected preamp valves as shown?
I was going down the path of getting EL34 valves for something different, I don't think 6L6's in these Rectifiers sound that good, either that or the preamp valves need something better.
Looking for a great, tight high gain tone but offering of versatility, am I only likely to find this by using a TS in front?
Any other suggestions appreciated
Thanks
Vince
V1 - Tung Sol 12ax7(Standard)
V2 - JJ ECC83(Low Noise High Gain)
V3 - Shuguang 12AX7B(Low Noise Hi Gain)
V4 - Shuguang 12AX7B(Standard)
V5 - Sovtek LPS balanced for Phase inverter position(Low Noise High Gain)
I see above that it's suggested a balanced phase inverter isn't required, I thought it would be a better idea?
What would you suggest as a PI valve other than the Sovtek to compliment the rest?
