beyer sm 250 wireless microphone - help needed as base unit fried and singer binned it (twat)
nickpnickp Frets: 183
hi
our singer who is an active chap fried the wireless unit for his beyer sm 250 mike.  He needs a new base unit (or buying a whole setup!!) - the frequency is not clear on the base of the mike
help - does anyone know what I should do next - can I lok somewhere in the mike to check the frequency; or can i get a base unit to work with it etc etc
I have no fookin idea as I can't sing and I play guitar - our singer is brilliant and a great "performer" but bugger me he is high maintenance
cheers guys
Nick
  • maltingsaudiomaltingsaudio Frets: 3136
    edited April 2014
    Get hold of another base unit and do a sweep for the frequency ... it would appear from this its a vhf model so probably around the 175 mark on the up side any base which works on the frequency the mic's on should work there should be the frequency marked on the base of the mic or in the battery compartment
    www.maltingsaudio.co.uk
  • nickpnickp Frets: 183
    @maltingsaudio - will it work with any vhf base unit then?
    and thanks!
    edited April 2014
    @maltingsaudio - brilliant - why didn't i read your post properly
    frequency is in the battery compartment!  have a wisdom.  it is 175.  do you have a recommendation on base units - will look on thomann
    genius
  • Should do but check if it has a thing called a "pilot tone" very unlikely but if it does turn that off. Thats a system which basically  identifies the make of a mic over a wireless system and stops them working with another manufacturers kit. With turned off should work with all makes.
  • thecolourboxthecolourbox Frets: 9814
    Was this what fried it?
    soundcloud.com/thecolourbox-1
