How often do you chaps change strings?
pintspillerpintspiller Frets: 994
I gig about every two months. 2 x 1hr sets. Rehearse once a week generally. Maybe two hours, at least half playing. Home practise anything from nothing some months to 10 hours a week.
I play mostly with fingers these days and change strings three times a year.
«13
  • FunkfingersFunkfingers Frets: 14434
    three times a year ...
    ... whether it's needed or not.
  • BridgehouseBridgehouse Frets: 24580
    With flats, I reckon it’s looking like 1-2 years per set.
  • martmart Frets: 5205
    Once per bass - to take the original strings off and put Thomastik jazz flats on. Then never again. Simples.
  • ToneControlToneControl Frets: 11901
    I use Elixirs. Every 2 years or so for less-used guitars, max every 6 months for busier guitars
    For classical guitars, not sure - not as long as that. probably 3 to 6 months
  • crunchmancrunchman Frets: 11449
    On the bass, hardly ever.  The current set have been on mine for 5 or 6 years as far as I can remember.  Didn't James Jamerson have the same set on for 20 years?
  • axisusaxisus Frets: 28338
    Electric - when I break a string I replace it. I hate the 'zing' of a new set, I prefer tired old strings. Bass, never.
  • octatonicoctatonic Frets: 33798
    On bass- 2-3 times a year.
  • Shark_EyesShark_Eyes Frets: 377
    About every 5 years. My P-bass is due a new set, and I'll do it when I finally get round to replacing the pickups.
  • slackerslacker Frets: 2238
    I changed the strings on the Musicman when I bought it in 2013. I last changed the Ashbory strings in 2008. The NXT still has the original strings from 2014.
  • ICBMICBM Frets: 72361
    Whenever I'm working on someone else's bass and it needs new strings...
    So never then?
    Unless its still got that original set on from 1978 and they are rusty of course...
    Bridgehouse said:
    So never then?
    I have actually never 'changed' the strings on my 4001. When I acquired it in 2013 there were no strings on it. I fitted it with a set and they're still on it...
    I will change them if they wear out or go dead of course, but there isn't any sign of that yet.
    ICBM said:
    Bridgehouse said:
    So never then?
    Rounds or flats?
  • TheMarlinTheMarlin Frets: 7875
    When they start to sound dead, and bass notes sound flabby, they’re replaced.  I probably get through 12 sets of strings a year across six guitars.
    Bridgehouse said:
    Rounds or flats?
    Rounds - Rotosound Roto Bass, which are far superior to the more expensive Swing Bass in my opinion.
    ICBM said:
    Bridgehouse said:
    Rounds or flats?
    Do you clean them from time to time ?
    Not often, unless I've been playing somewhere hot. I don't sweat a lot normally though.
  • WezVWezV Frets: 16680
    edited July 2018
    No one boiling their bass strings then
    I tried it. Bit of a faff and I'm not sure I noticed a difference.
  • MattBansheeMattBanshee Frets: 1498
    Measured in years not months. I've changed strings on 3 basses in the last 12 months, two of which were straight after being bought on ebay, and the other hadn't been played for 10 years and was getting a full overhaul.
