How to use non-tap-tempo delay?
BigMonkaBigMonka Frets: 1777
I've bought a cheap delay pedal to try as I've heard people say that they can thicken up your sound and give a bit more sustain.
But I can't work out how to set it without it sounding out of time with what I'm playing. Any tips on how to set it to stop it clashing? Or should I just go back to a tap-tempo delay like I'm used to?
Thanks!
  • Moe_ZambeekMoe_Zambeek Frets: 3423
    Shortish delay and mix low with minimal repeats for thickening. If the mix is too high and delay too long you perceive the timing discrepancies more.
  • randersonranderson Frets: 187
    The tone of the repeats can also be a factor. Too bright and they can get in the way. There's a reason why darker delay pedals like the MXR carbon copy, DMM and the Ibanez Echomachine are favoured for this type of role. They can sit just under the notes you are actually playing.
  • KeefyKeefy Frets: 2286
    If you want to thicken your sound by creating the illusion of a second guitar playing almost in time with you (doubling), go for a very short delay time with no repeats.
    For a more obvious echo that still doesn’t get in the way, try to get the repeat to fall half way between the beats. It’s also worth bearing in mind that the delayed notes will sound less prominent when you are playing in a band setting than when you are playing on your own at home.
  • EricTheWearyEricTheWeary Frets: 16297
    You can also use quite a prominent single delay for a rockabilly slapback.
    As has been said you can have more feedback and have it sit under what you are playing ( similar to a long reverb). Whilst darker delays are usually better for this you could try mixing delay and modulation for this kind of ambient wash.
    Adding reverb to delay will soften and extend the delay tails which can sound more natural and, again, sits under what you are playing rather than fighting against it .
    are you using clean or dirty ?  in a loop or in front ?
  • BigMonkaBigMonka Frets: 1777
    Thanks @Moe_Zambeek I'll have a play with it set like that.
    randerson said: The tone of the repeats can also be a factor. Too bright and they can get in the way. There's a reason why darker delay pedals like the MXR carbon copy, DMM and the Ibanez Echomachine are favoured for this type of role. They can sit just under the notes you are actually playing.
    @randerson I'll try knocking the tone down too, I hadn't thought about that - thanks.
    @JMP220478 generally it's clean and in front of the amp (although I've got a loop on my amp but haven't tried it in that)
