Miking a Bodhran
Does anyone have any experience of miking an Irish Bodhran or similar frame drum for a recording session? I've got a pretty limited mic selection, which consists of the following:
3U audio Warbler Mk1 cardioid condenser
Line Audio CM3 small diaphragm condensor
Golden Age Project R1 active Ribbon mic
Ideally I would use just one mic to keep things simple but 2 is also a possibility if that's really going to benefit the sound.
So my query would be about mic distance and mic placement and also I suppose if the mics I have are suitable or if I should look at getting a dynamic perhaps?
Cheers,
Dom
  • octatonicoctatonic Frets: 33848
    Any LDC about 1ft away will do.
    Multi mic option add complexity and you have to account for phase.
  • domforrdomforr Frets: 326
    Simple is best - sounds good to me! I'll bear the distance in mind as I think I was previously miking quite close, which probably wasn't helping much.
  • PolarityManPolarityMan Frets: 7300
    I was going to post suggesting just a room/overhead style mic position when i think of a bhodran sound its the opposite of a close mic sound for me.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • CirrusCirrus Frets: 8495
    If you're not sure, use a close mic as @octatonic suggested, and a room mic wherever you think it sounds best in the room. If, indeed, it's an ok sounding room and doesn't sound bad everywhere in the room (I speak from bitter recording experience here).
    Yes, that will bring up phase considerations. But you don't have to use both tracks, you can throw one away once you have a chance to try them out. Or do the dirty track nudge if you want.  :o
  • Winny_PoohWinny_Pooh Frets: 7802
    Def worth trying this, too close and you get the woof (for lack of a better) of too much air movement and levels/attack being a bit spiky. When you then try and compress said spiky bits it goes to hell.
    What about the possibility of using one on the skin side and one behind to capture some of the bass? Is this complicating things too much?
  • RockerRocker Frets: 4993
    Ask Christy Moore.
    Nil Satis Nisi Optimum
    The problem with using a room mic in (what I assume is) an untreated room is you will often end up with room modes affecting the recording quite significantly.
    An LDC about a foot away is the best approach to take initially.
    If that isn't working then pull back and see if the room positively or negatively affects the recording- in my experience with many percussion instruments it makes things worse.
    But with all things it is best to experiment in situ and see what sounds best.
    For instance you might find your ribbon mic works really well in a bright room such as a bathroom.
    Great, many thanks for the useful advice. I'll experiment a little, but it seems the simpler option in an untreated room looks the best way to go.
    Or the metalcore approach: close mic into trigger 2 into a vst  (then paralell compressed and clipped) :D
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
