6G Beam Internet,,,,anyone using it ?
spark240spark240 Frets: 2093
one of my Xbox gamer pals is using it , reckons it’s ok.
You don’t need a BT line .
Mac Mini M1
Presonus Studio One V5
 https://twitter.com/spark240
Reddit r/newmusicreview
    The 6G name is just the brand, this is basically a router that has a 4g cobbection rather than a fibre one.
  • RedRabbitRedRabbit Frets: 486
    Not sure if it's the same as I've got or not. Mine was described as microwave broadband but reading a bit in the site it sounds a similar set up - a dish/receiver on the side of the house which gets the signal from an access point.
    Mine has been great. I'm in a rural area and the best speed I could get from BT was 2Mb. The new system gets up to 30Mb.
    If you've got the option of a wired service that gets similar speeds I think that would still be the better choice but if you're in an area that otherwise doesn't get super fast broadband then these solutions are well worth considering and seem to be cropping up all over the country now.
  • robgilmorobgilmo Frets: 3623
    What service provider does that then? We are in the deepest depths of rural Suffolk and our connection is Victorian.
    Mine's with Derbyshire broadband. I think I found someone offering a similar service around your area when ttony was having trouble with his internet.  I'll have a look later to see if I can find them again.
    @robgilmo this is the one I found last time
    Should be somewhere on their site to check if they cover your area
    https://www.radesystems.com/solutions/internet-connectivity
