Fed up with heavy 1x12 combos - should I splurge on some neo creambacks?
bbill335bbill335 Frets: 1374
As above really. The Traynor YGM3 is heavier and bulkier than my vibrolux reverb (and with an emi C.rex in there, basically just as loud). The WEM westminster has a super efficient and trebly Fane-looking thing that I want rid of anyway, and the lighter the better for that one - what should be a neat, portable combo is a hefty lump with an awful beamy treble coz of a PA cone.
The neo creamback is a spendy driver and I don't doubt they sound decent. It'd be nice to hear some opinions from people who've used them.
  • Winny_PoohWinny_Pooh Frets: 7770
    YGM3s never had a great speaker to start with. I'd go so far as to chop down the cab to a smaller 1x12 open back size as well as put in a creamback. This would involve chopping the sides and lifting up the bottom panel, then moving up the baffle into the chassis section.
  • robertyroberty Frets: 10893
    edited August 2018
    Slight tangent but I got a G12 Century Vintage in the post today, which is also a neo magnet, picked up for a reasonable-ish price used.  It's a potential candidate for replacing a Celestion Creamback 75 in a DRRI combo.  The neo is 3kg lighter.  I can report back once I've had a blast if you like
    https://celestion.com/product/14/g12_century_vintage/
  • ICBMICBM Frets: 72360
    For the Traynor I would also consider a Jensen Tornado - they're fantastic in more American-sounding amps, and in fact I recently fitted a pair in a Traynor YGL-3 2x12", which made it sound great and almost light enough to lift :).
    For the WEM I would look for an old Celestion G12L-20 or G12S-20 if you don't want to spend too much - period-appropriate, quite light due to the small magnets, and the tone really suits the amp.
  • bbill335bbill335 Frets: 1374
    This is exactly what I wanted to hear. Thanks mate! Hope the arm's not holding you back too much!
    1: there's a Crex in there, which replaced a ceramic jensen (fine but a bit "small" sounding while it was my only gigging amp). I've never experienced the marsland drivers that came stock on them
    2. No chance! I'd sooner get a head cabinet built and mount the chassis in that, run it through a separate speaker cab
    So would you go for any specific one over the others? I'm leaning to the 65 over the others for the ~1db less efficiency, but the Neo 12/100 is the least heavy (though they're all around 2kg, +/- a couple hundred grams).
    I haven't actually tried any apart from the original Classic - but in the demo samples, that's also the one I like the best. I think the samples of the Classic are pretty accurate, so I would assume the others are too. The weight difference is fairly trivial compared to the difference compared to a normal ceramic speaker - the Classic feels lighter than the box it comes in :).
  • fandangofandango Frets: 2204
    Got a Neo Creamback fitted to my Princeton (to replace the Stock Celestion G10-30.
    Noticeable weight reduction.
    The combo has lost a little fender clean chime, but gained a bit of beef across the frequency range. Now copes with bass far better than the 10-30 ever did.
    A heavy 1x12?
    You girl :-P
    edited August 2018
    Annoyingly, the Jensen Tornado Classic isn't listed for sale on hotrox or thomann  :/ dangit
    A heavy 1x12?
    You girl :-P
    The Traynor is built to outlive everything, especially regressive statements like this.
    Seriously, I have health problems that motivate me to try and strike a balance between weight/ usefulness, and the WEM has no business being as heavy as it is when it's so small. I wish it were a Princeton (or at least a Pro Jr) but this is what I've got to work with for now!
  • richardhomerrichardhomer Frets: 24807
    edited August 2018
    ICBM said:
    For the Traynor I would also consider a Jensen Tornado - they're fantastic in more American-sounding amps, and in fact I recently fitted a pair in a Traynor YGL-3 2x12", which made it sound great and almost light enough to lift .
    I have a 100 watt Jensen Tornado which I bought on @ICBM’s recommendation in my early 80s Musicman RD50. It sounds phenomenal - great Blackface cleans and really bold when overdriven.
    My was £99 delivered from Hotrox - really good value. The whole (50 watt) combo weighs about 30 lbs.
  • telehacktelehack Frets: 93
    Gotta agree on the Jensen Tornado Neo. Had one in a Deluxe Reverb and couldn’t fault it. Not just a great neo speaker, but a great speaker full stop.
    Oooooohhh, facepalm moment here! So, it seems the "stealth 100" is the same as the "classic 100", just with a magnet cover! I mean, I think so? After a tonne of googling, clicking around different Jensen/Sica sites, that's the conclusion I've come to.
    This is the one - though they look different to the image shown on the site:
    http://www.hotroxuk.com/jensen-jet-tornado-8oms-neo-100-speaker.html
    Really impressed with the Celestion G12 Century Vintage after giving a quick blast today.  Really well balanced and sounded great with clean and high gain.  It will show up your picking technique.  There's a few neo options in the Celestion range
  • PolarityManPolarityMan Frets: 7287
    I have these..they're a tad ice-picky compared to real V30s but ive been using it as my main speaker for 5+ years.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    @PolarityMan I did notice a smidge of harshness on the bright channel with P90s at house volume (2-3), was tameable with tone control though. Not wound it up yet
    Yeah I mean Im talking about maybe 5% in it between the neos and real V30s and for me the weight saving is worth the trade foff, especially once you're in a full band mix.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • WazmeisterWazmeister Frets: 9542
    Yes !! Ive got a Neo in a Zilla 1x12 - dead light and sounds great even with the Kemper through it
  • rlwrlw Frets: 4696
    A heavy 1x12?
    You girl :-P
    Have to say I was thinking that....
    rlw said:
    A heavy 1x12?
    You girl :-P
    I challenge anyone to walk 200 meters or more with a guitar, pedalboard, bag of leads/bits and a Traynor YGM (again, built like a fuckin nuclear bunker) and not think "it would be nice if this was easier". Or, you can stay stuck in the 70s with yer silly gendered insults.
