Hissy compressors
smigeonsmigeon Frets: 284
Hi all,
I recently bought a Mooer Yellow Comp compressor for my mini board. I'm really impressed with it - it's just what I like in a compressor: nice and transparent and helping to bring out the subtleties. And cheap!
Only problem is, it's a bit hissy, especially when I put it in front of my Rat, or into my Roland JC-40. Much more so than my "main" compressor, which is a T-Rex Comp Nova.
From what I've read, there are other nice mini-sized compressors around that are in a similar vein - I'm thinking especially of the Fairfield Accountant and the Xotic XP. Of course these are more expensive that the Mooer, but I might stretch to one if it's less hissy than the Mooer. Anyone know if this is likely to be the case? Any experience with these compressors??
  • impmannimpmann Frets: 12678
    Marshall Ed the Compressor.
    Cheap as chips. Sounds better than most compressors at any price.
    Oh and quiet.
  • smigeonsmigeon Frets: 284
    Thanks. Edward the Compressor - love the name! But do they do the subtle transparent thing for jazzy cleans? I thought they were more for the sustained dirty tone thing. And I think one of those would be too big to fit my mini board (Pedal Train nano).
  • octatonicoctatonic Frets: 33842
    Be sure that it isn’t source related.
    Compressors, by design, raise the noise floor.
    Putting a comp on the front end of a distortion would and should make the noise more obvious.
    You won’t hear it when you are playing.
    Noise can be exciting to listen to, as well.
    I frequently crunch things up just to get a mix sounding less clean.
  • Boss CP1X it’s lovely! I can’t get a bad sound from it, and it’s quiet
    Yeah, i know what you mean, but here I’m going more for a pristinish clean thing with maximum nuances (was probably misleading me mentioning the Rat - this is not actually the main use case, it’s just that it gets *really* hissy with the Rat).
    My T-Rex Nova Comp is nice and quiet, and I’m just hoping for a mini sized compressor that does a similar job. The Mooer sounds damn fine - just as good as the Nova Comp - apart from the damn hiss...
  • BabonesBabones Frets: 1206
    Not mini, but the Rothwell Love Squeeze has no hiss at all. Very silent.
    Yes, its a proper compressor - I use mine for Gilmour-esque clampage and its as transparent as you set it. I don't use it for a sustained dirty tone... And its no bigger than a Boss pedal (and a shit load nicer sounding!).
    Seriously - I've had some very expensive compressors (Keeley, Rothwell etc) and I kept this.
  • MikeBMikeB Frets: 176
    edited August 2018
    If you like the Mooer it's based on the Diamond Comp which I had. It was exceptionally quiet.
    Ah, thanks. I need to try one in a shop I guess...
