I know this is not an ideal set-up, but at the moment I don't really have a choice so I'm looking for ways to improve this if possible.
I'm in the corner of a mid-size lounge so there's lot's of space behind me but obviously, there's a wall (with an open window to the kitchen) to my left.
I've used some very simple acoustic tiles behind the monitors and on the left-hand side wall and I've also set up the ARC sound correction software to try and compensate for the poor acoustics. Is there anything else I can do to improve the sound, or should I just stick to mixing on good open back headphones which do seem to give a more accurate sound?
My rooms not great, so I tend to mix a lot on cans, the try them mix in different rooms against a commercial mix that Im trying to emulate, the best feedback you can get is to post some mixes here or elsewhere and wait....youll soon get the idea !
https://twitter.com/spark240
Reddit r/newmusicreview
Either way if headphones are involved this should help a bit;
https://youtu.be/V1cyEm6TRZ0
I usually use open back headphones. Anyone talking in the same room would make mixing impossible for me at the volume I listen at. But they leak everything in.
