Tele body with TV Jones Classic and Tele bridge pickup.
dazzajldazzajl Frets: 5776
A few little bits from a guitar that gave it's neck and Bigsby to other projects.
The body is from a Squier I believe, its a bit rough, it's very heavy, covered in thick black poly and is drilled/routed as a Cabronita with a Bigsby. The most interesting and valuable part of it is most likely the TVJ Classic that's been stuck down into the neck pickup pocket. £60
From the same guitar is a bridge pickup. Looks like a pickup and has a CS sticker on the back. That's as much as I know about it other than it was rocky, gritty and snappy in the guitar and was a great match for the Filter. £40
https://lightart.zenfolio.com/img/s/v-3/p3028795813-5.jpg
https://lightart.zenfolio.com/img/s/v-3/p3028795846-5.jpg
https://lightart.zenfolio.com/img/s/v-3/p3028795871-5.jpg
https://lightart.zenfolio.com/img/s/v-3/p3028795874-5.jpg
https://lightart.zenfolio.com/img/s/v-3/p3028795931-5.jpg
https://lightart.zenfolio.com/img/s/v-3/p3028795943-5.jpg
https://lightart.zenfolio.com/img/s/v-3/p3028795954-5.jpg
  • DrBobDrBob Frets: 3006
    When you say “stuck down” will it not come out ?
  • dazzajldazzajl Frets: 5776
    Exactly that @DrBob ;
    There are no visible fixings and it doesn’t want to budge
  • TheMarlinTheMarlin Frets: 7888
    Might just be a bit of double sided tape in there.
  • rexterrexter Frets: 369
    I bought the body any pickup from Darren - a pleasure to deal with him. Highly recommend!
    And... got the pickup out. Some kind of super-tough amber resin in there moulded all around it. Cut a truss notch in the body then scored all around the edge of pickup with a razor blade to loosen the seal. Popped out with a bit (well quite a lot) of persuasion. It's an English mount TV Jones which has had the ears snipped off as far as I can see. Perhaps I'll replace the mounting plate in due time. Thanks again Darren!
    Custom colours, vintage restorations, high end guitar finishing
    www.rexterguitars.co.uk
