Love Mesa Mark amps and I think the Mark V is an absolutely amazing amp – they took the Mark IV and made the control layout, well, sane I guess
I also think the IIC+ mode is pretty spot on for what they were trying to achieve, remembering that it was modelled on a specific IIC+, not all the IIC+’s ever made. Does it wound like a IIB or a Mark III – not 100% the DNA is there and I’m sure you could get close enough that you wouldn’t know in a blind test.
As to the cone of death you get from of all the Mark series combos, the MC90 in the combo to a certain extent does not do this as much as the EV12L does and the Mark V only comes in the wider format combo and head so the smaller format IMHO added lot to this narrow spread. TBH I still bought a head and vary the speaker format as the venue dictates, normally a 2x12, but when using a 4x12 it’s amazing!
I find, for a Mesa, the master volume is surprisingly good – the older marks had a volume taper that was pretty much on / off in some cases. And it sounds good at all level of wattage settings and all volumes – I use mine in the house with no issues. You also have the 90/45/5 watt settings to play with too, thought I find they change the feel way more than the actual volume.
If you like the Mark sound the Mark V is hard to beat, so unless you want the IIC+ sound in which case get the JP-2C, I’d say the Mark V is a more rounded amp.
It can be a loud amp, even on the 10 watts setting but the master volume taper is good and I'm currently really enjoying the crunch mode on 25 watts set for a lightish crunch and use it at home volumes no problem. It sounds quite “Marshally” on the crunch mode.
Something I do really like on the 35 (it's on the Mark V 25 too) is the active mid/gain boost on the channel 1 mid control, which starts to work as you dial past 12 o clock, it can get the clean mode clipping nicely for a Texas Bluesy driven Fender type thing.
Another useful feature is the 2 independent footswitchable solo boosts on each channel, these can be set to reduce volume as well as boost, it's like having 2 clean boost pedals in the fx loop.
if I was gigging I would probably add a Thiele 1x12 to sit underneath.
