Jet City 20 combo
scarry67scarry67 Frets: 143
Any reason I shouldn’t buy a cheap one advertised locally?! (£125)
  • FelineGuitarsFelineGuitars Frets: 11594
    Not a bad price . Be aware it hasn’t got the huge gain like the SLO. More like the Atomic 16 amp
    Depends totally on what you need it for.  They're decent amps if that helps.
  • scarry67scarry67 Frets: 143
    Is it aimed at heavy rock? I’m more of a Wedding Present man....
  • ICBMICBM Frets: 72345
    Good amp, but you may want to change the speaker - which you can afford to if you get it that cheap - I find them a bit lacking in bottom end with the stock one.
    It will do a decent light-breakup sound as well as the high gain.
