Right you talented crowd of luthiers and guitar modification freaks: prepare to be amazed AND all advice gratefully received.
The brief: I recently acquired this rather jolly LPJDC which I'm really rather fond of. A LOT. But there's this one thing: even with my trim, toned midriff as befits a 47 year old lawyer, the original position of the neck end strap button (Fig. 1) tended to dig into the paunch, causing irritability and distraction from playing Dad Rock riffs.
What to do? Well did you know that with craftsmanship and the deft application of precision tools, said button proved capable of removal?! Problem solved! (Fig. 2)
But not quite: the issue that then arises is where (if anywhere - a kinda prequisite of having any pretensions to playing the thing standing up) to replace it? Should one go for the tip of the top horn, shown yellow (Fig. 3), or slightly beneath it, as in the blue example? Would either be likely to cause neck dive?
All advice, as ever, gratefully received.
Fig. 1: original strap button in situ.
Fig. 2: strap button removed! A schematic for the correct procedure can be made available, if required.
Fig. 3: the amateur luthier's dilemma.
Inactivist Lefty Lawyer
Just make sure you drill the hole properly, or there is a possibility of splitting the horn.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Why do these and SGs tend to have rear mounted buttons? Not being critical, just intrigued...
So the solution is less pies, clearly !
Instagram
