Amber or heavy tint is often harder to control, lighter tints take more time but are easier to control.
Instagram
The fan on those cans should be enough to get an even tint with a few overlapping passes and the light tint is exactly what you want.
Measure how how far you are holding the can away from the surface if unsure, let us know what it is.
also, are you moving the can parallel to the surface, it’s easy to swing it side to side instead.
Instagram
Sounds like it's going on too heavy, too close or two slow, or a combo of those. Maybe overlapping too close
Passes should overlap partially, outside of the the heavier wetter part in the middle of the fan. If you can, watch it go down from an angle, with light hitting, you can see the difference between too thin/dry and becoming wet. If you see it lay down thick, back off and/or move quicker. If going down a bit dry looking, slower/closer.
That'll help get the speed right and the amount laying down too.
Once that's sussed do a coat say along the body length, and next coat cross wise, another way to get more even cover and help avoid tiger stripes. But figure out the speed & distance thing first, that's really the key to it all.
