The ValveKing 412 is a heavy duty loudspeaker cabinet designed to perfectly match the powerful ValveKing head. It is available as a slant cabinet and loaded with four rear-mounted, custom-designed 12" ValveKing speakers. The ValveKing 412 can accommodate any playing style and emphasises the low end while allowing chiming mids and highs to cut through for tight, rhythmic playing and thick chords.
Power handling:
400 watts continuous
Transducer complement:
Four custom-designed 12" ValveKing speakers
Impedance, Z:
16 ohms mono
Input connections:
Two paralleled 1/4" phone jacks (daisy-chained paralleled outputs)
Enclosure materials and finish:
1/2" plywood sides, birch plywood baffle, closed-back construction
Dimensions (H x W x D):
29-3/8" x 30" x 14-1/4" 746mmx762mmx362mm
Net weight:
65 lbs. (29 kg)
