best way to shield a strat?
Is shielding paint OK or would I be better to use the stick on foil stuff, or .... something else?
Any special considerations?
  • ICBMICBM Frets: 72716
    I prefer self-adhesive copper foil. It's more of a faff than paint, but I've found it more effective - several times I've used it to fix a paint-shielded guitar which is still causing trouble, and always fixed it. You do need to spot-solder across every joint (just in one place is fine) and connect it properly to ground with a soldered-on wire to absolutely guarantee complete conductivity, but that's not much work, it's the cutting and fitting which is.
  • MegiiMegii Frets: 1670
    I would recommend doing the bottom of the routing first, with pieces cut slightly oversize, so they just go up the sides a bit, then go round the sides with pieces wide enough that you can just fold a little over onto the top surface. Use spots of solder to ensure electrical continuity as ICBM says (I do this even if the foil is supposed to have conductive adhesive - it doesn't always seem to work that well). I also run strips of copper out out to some of the pickguard screw positions, as there is a clamping effect between scratchplate and body that helps with getting a good electrical connection.
