Yes. Did it with Sporkaster 1, which has a Variax 300 inside it. Not helped by being a bit undersized, but it's perfectly DIY able.
Does this help and as you've probably seen, there's quite a few things out there on the internet on this
https://shop.rall-online.net/Guitar-Making/Neubau/Variax
I can't remember if Charlie Chandler had done one
Jonathan @FelineGuitars - Have you ever done one?
The JTV system is probably (imho) the easiest especially if you intend running pickups as well.
Bear in mind that Warmoth can make you a body pre cut for the variax bits (Tele or Strat shaped). Not the cheapest but a lot neater and easier than some!
I had to have custom ribbon cables made up for mine.
I have the guts of a 300 (or a 600), which I've removed from the coffin and connected to a rare DIY RackVax interface (picture below). This way, I can get all the Variax sounds from a Roland-ready guitar. It's not as handy as having all the controls on the guitar, and at the moment it's just a bunch of bits looking for an enclosure to live in, but I'll get around to that one day soon.
The version I have also works with the newer JTV/Standard electronics, but unfortunately they're not readily available without sacrificing a guitar.
