I said maybe.....
Are you sure? The case looks fairly well-done for a DIY job, and the soldering inside some 70s/early-80s Japanese pedals was horrendous!
Sounds like it's probably a flanger.
My boss seems to believe it’s a home made attempt and he was trained by the bbc a while back. Sending photos will be difficult although as there is a lot of foam/sponge material that is being kept in place by some wiring used for the mains supply.
