So i'm in...
I have a guitar which i have intended to do something with, so something will be done with it.
The kit part the voices say!?
I, Luttis Reginald Von Forum-Member fully intend to build.... Some pickups from a kit.
Still deciding on which ones, but guitar sorting comes first but it will probably be some sort of humbucking bridge mounted titan of pickup hugeness. I've never attempted anything on that side of diy so i will be mainly attempting to not burn the house down. That's a win in my book,. I'm aware that it probable doesn't involve fire, but that won't stop me!
The designs!
So i've had these ideas floating in my head as to what i want to do...
Firstly, the Furry Pink Zebracaster, a hotrodded 80's monster, designed over a cauldron heated with hairspray and hookers. It will be upholstered in the Internets finest and cheapest polyester material. The pickup will be singular and pink. It will be made for bandanna's and aviators.
Or in the hopes of enticing my daughter to guitar even more (she already likes it, just this might be for her) i will make her a Sparkling Rainbow Dashcaster. Inspired my a certain flying horse that i get subjected to a fair bit.. But it also sparkles, so that's ok in my book.
This one is potantially the easier finish as it's spray paint and sparkles. It will also be satisfying because it has sparkles and i will get to hacksaw rainbow dash for the top of the tail... and i like the strap
I found a couple of potential kits including one that has some quite cool blue foil covers which might go nicely.
So uh, currently preparing the guitar for doing stuff and mulling over the designs.
Thoughts opinions and preferences are welcomed
I actually considered making a copy of the guitar from Rainbow rocks
Instagram
Just because you're paranoid, don't mean they're not after youQuite enjoying this research phase. For those counting research, that is series one episode 27.
I now know that friendship is indeed magic.
Here is the guitar that will be dismantled and rebuilt:
We have the technology. We can rebuild it... Better.. Stronger.. Faster.. More Sparkles.
It did get better though...
It really is amazing what you can accomplish if you duck out of work early and come home to find your child is at her Nana's and your wife is at a meeting...
So i bought this guitar for £20 a while back. I have now looked at the back of neck for the first time...
Doh..
Couple of cracks hiding on the back like complete bastards.
In the great scheme of things reckon it's a major problem? Any suggestions for dealing with them? Do they need dealing with?
Great choice of t-shirts so far!
if all is relatively strait then for economy I would look buying the thinnest watery super glue there are different grades. I would by a specific viscosity rather than Poundland special then using a fine hyperdermic would wick a load of super glue in to the cracks
As far as a fun projects cheap upgrades go I would just do the glue thing. neck breaks headstock area are more than strong enough after glueing. So in filling a long crack should be stable enough with a load of watery super glue.
Since i need to do the 'rainbow tail' type bit going through it all, i thought a pack of sprays LIKE THIS might be a good shout, as i only need to cover a small area and for a tenner it has multiple colours.. an neon is always a bonus.
but then i got to thinking, which is when things usually stop working so well..
Would the neon mess with the sparkles? (the rustoleum clear sparkle spray is my intended sparkle method unless anyone has a better idea)
In particular if i was to use the blue neon can from this set with some additional for the actual blue of the body?
Uh.. I mean primer sanded and other spray paints all arrived.
Didn't do any sanding or prep, it's just a bit of primered wood, with colours, and then with clear glitter spray.
Quite happy with the result.. imagine when i actually but some effort.,gerbpoeopib zzzzzzzzzzzzzzzzzz
