I prefer to have a neck as straight as it will go, but all guitars are different and some need more relief than others.
I'm not sure totally flat is usable/sensible, unless you are a shred/speed player with loads of gain and play with a light touch
I have minimal relief for my own guitars but still just a hint of relief can be seen when checked - Shop stock and I'll set up with a hint of extra relief but will always adjust as required by the customer
Also remember with less relief, there is zero tolerance for any 'movement' that the summer to winter might bring, so be prepared to check and edit accordingly - Likewise winter back to spring - Does not always happen - depends on the guitar, temperature of surroundings etc
http://www.thefretboard.co.uk/discussion/140374/bridge-options-for-a-korean-epi-les-paul#latest
Depends what action you need - I don't have it shred metal low but I still require an easy 'girlie' action that responds to a light touch - SRV would have hated such a set-up but it gives me a well balanced set-up across the whole fingerboard
