Inadvertently duplicated post - please ignore
jaymenonjaymenon Frets: 821
edited April 2019 in Parts £
Musikraft Stratocaster Neck Maple Brazilian Walnut 1-11/16" nut 6100 SS frets £300
New, never been fitted
Original Musikraft box
Tru-Oil finish
Maple shaft  / Brazilian Walnut Fingerboard
12" radius
Nut Width: 1-11/16’
Stainless Steel 6100 Frets
Neck Profile: Medium C
HEEL: 2-3/16 (55.56mm) Standard Fender
TUNER HOLE: 11/32 Vintage Kluson
Single Acting Truss Rod with Vintage Double Slotted Adjustment Nut at the Heel
NUT SLOT: 1/8 Standard Fender Flat Bottom Style
SHAFT WOOD: Rock Maple
FB WOOD: Brazilian Walnut
FB STYLE: Slab Standard Fender
TOP DOTS & INLAY: Imitation Clay
SIDE DOTS: Imitation Clay 2mm
FRET WIRE SIZE: 6100 Stainless Steel
FB EDGES: Semi Rolled Standard
BACK PROFILE: Medium C 83 92
MOUNTING HOLES: Drilled Standard Fender Pattern
[Imgur](https://i.imgur.com/aGBBeDt.jpg)
[Imgur](https://i.imgur.com/DmgHGPP.jpg)
[Imgur](https://i.imgur.com/w8Cloi6.jpg)
[Imgur](https://i.imgur.com/O5aBLzx.jpg)
[Imgur](https://i.imgur.com/vpcfdmg.jpg)
[Imgur](https://i.imgur.com/ORbps5e.jpg)
[Imgur](https://i.imgur.com/Q4Zudre.jpg)
[Imgur](https://i.imgur.com/gnO4W3o.jpg)
[Imgur](https://i.imgur.com/6Yhy016.jpg)
[Imgur](https://i.imgur.com/L2kEFT2.jpg)
[Imgur](https://i.imgur.com/ynwZUp8.jpg)
WITHDRAWN
Kinman Traditional Mark 2 Stratocaster Pickups K9 Harness Loaded Black Pickguard £225
Black 3-ply pickguard.
The traditional Mark 2 sounds brighter than the Mark 3 - more sparkly and genuine vintage strat (I feel they dulled the mark 3 to highlight the sparkle of their Impersonator range)...
Bridge: Avn 62b
Middle: Avn 56
Neck: Avn 56
Plenty of quack in the in-between positions
Black pickup covers without the Kinman logo - the logo looks wonky and so I carefully removed it...
K9 harness:
1. Push-Push pot to switch position 2 (Bridge + Middle) between series & parallel
2. 2nd tone control: 'Neck Roll-In’
3. Choice of Tone Capacitors (22nf and Kinman’s Hi Definition Cap)
Output cable
Flat stagger
[Imgur](https://i.imgur.com/Bk4SMzC.jpg)
[Imgur](https://i.imgur.com/wGm28JG.jpg)
[Imgur](https://i.imgur.com/EvSPol6.jpg)
[Imgur](https://i.imgur.com/SlLxsSS.jpg)
[Imgur](https://i.imgur.com/Mmefhcv.jpg)
[Imgur](https://i.imgur.com/JPqnnQm.jpg)
SOLD
Musikraft Alder Body (sold on eBay)
Wudtone Holy Grail Bridge £70 SOLD
- 2-7/32” (56mm) screw spacing
- 2-11/16” (52.5mm) string spacing
- bent steel saddles
- Gilmour tremolo arm
Wudtone Constant Pivot Vintage 50s Tremolo Bridge £70 (sold on eBay)
2-1/16" (52.5mm) string and screw spacing
(Fits the alder body perfectly)
Bevelled Steel Block with Delrin insert by Kevin Hurley (who makes trem blocks for Wudtone)
Tremolo arm with cream tip
Bent steel saddles, Whacker Plate, Hardened steel screws, Claw, Springs etc...
Set of Kinman Woodstock Plus Strat pickups SOLD
White covers
Graduated pole spacing (52.5, 51 and 49.5mm)
Flat stagger (supposedly better for Warmoth and Fender compound radii, though I must admit, I have a 7-14” radius set on my Warmoth Strat and don’t hear a string balance problem).
Stratocaster Body including Non-Fine Tuner Floyd Rose Tremolo £250
- One piece Swamp ash
- Tobacco Sunburst / Nitrocellulose Finish by Rich Rendall (lam68)
- Contoured Heel
- Shielded with graphite paint
- 1.83kg (4lbs)
- Includes
     - Tremolo
     - Three pickguards (black, white and parchment)
     - US Deluxe style Neck plate and screws
  • jaymenonjaymenon Frets: 821
    Bump
    Bump
  • lentolento Frets: 116
    Are you keeping the neck ?
    edited October 2018
    Hi Lento
    I hadn’t originally planned on selling the neck, which was made for me by Martin Sims.
    However, if it would be more convenient for someone to purchase the guitar as a whole - then yes I would consider selling it.
    Another option is of course to buy the fully loaded body (with the loaded pick guard) - so all that remains would be to attach a neck...
    Martin Sims Neck £300 (cost me £450)
    - Slim C
    - Birds Eye Maple
    - Dark Indian Rosewood fingerboard
    - 16 inch radius
    - 22 x Stainless Steel 6100 frets (1.4mm high x 2.8mm wide)
    - Back angled headstock - with scarf joint
          (no need for string trees)
          (no risk of headstock breaks)
    - Bone nut with beautifully cut slots
    - Generic locking tuners (do the job perfectly)
    - Rich Rendall (lam68) could easily remove my name from the headstock and put on a custom decal of your choice
    Loaded pickguard (£200)
    Kinman Traditional Mk2 flat stagger with K9 Harness
    Allows
    2nd tone pot is a push-push for series / parallel switching of Bridge + Middle pickups
    2nd tone pot is a Neck roll-in / roll-out
    [Imgur](https://i.imgur.com/D9VkO0j.jpg)
    [Imgur](https://i.imgur.com/AmZzFZi.jpg)
    [Imgur](https://i.imgur.com/8rWBhbZ.jpg)
    [Imgur](https://i.imgur.com/EHqSssg.jpg)
    [Imgur](https://i.imgur.com/AFinSzf.jpg)
    [Imgur](https://i.imgur.com/oR8QMO5.jpg)
    [Imgur](https://i.imgur.com/eXfSYoX.jpg)
    [Imgur](https://i.imgur.com/WUeGsHi.jpg)
    Thanks for the reply Jaymenon. A lovely looking guitar and I'm also a fan of a flatter radius on fretboards.
    My Yamaha's are 13.75.
    I'll be thinking this over regarding the whole guitar .....
    Are you anywhere near Manchester ?
    I have a Yamaha SA700 that's 13.75 too...
    I live in Great Yarmouth - Norfolk.
  • Arw, this would go well as a companion to my Ibanez AT...
    Bump
    Bump
    Bump
    Bump
    Some new stuff added...
    Bump
    Bump
