There's an amp for sale in the classifieds that is 100w, switchable down to 25w ...but the owner says if you pull two of the four valves, it'll go down to 60w / 15w.
Now, apart from not being able to work out the maths there; aren't circuits/transformers/whatever all designed to work in a certain way because exact components, in specific quantities, in a very definite order, are all supposed to be there? Won't pulling valves damage the amp? If not, why not? And can it be done to any amp with more than one valve?
Not much of the gear, even less idea.
(In fact, there may be a *small* rise above the exact half power, but it's not likely to be as much as 20% even on the 50W, and on the lower setting it definitely won't be.)
Yes and no. In a four-valve amp, it's most common for them to be arranged in two pairs, where essentially each pair is operating in parallel as if it was a single, larger valve. (There is actually only one exception I know of, more about that later.) So by removing two of the valves you still have the same circuit, but with half the power capability.
In order to do it correctly you also ideally need to reset the output transformer's impedance ratio, because that is designed for the four valves - to do that, you need to set the amp to half the impedance of the cabinet, because that retains the correct ratio between both sides of the transformer. If you don't the amp will be running mismatched, although that is not likely to be very harmful.
All of the above relies on the amp being either fixed-bias, or cathode-bias with separate resistors for each valve. If it's a more typical cathode-bias amp with one resistor for all four valves, you can't remove two valves because then the remaining two will bias themselves far too hot and fail - trying to do the job of the normal four - even if you reset the impedance.
So almost any four-valve amp which is cathode-biased (sometimes mis-called Class A, and most often using EL84s - eg Vox AC30) cannot have two valves removed. But almost any amp which is push-pull fixed bias with four or more valves can safely have pairs of valves removed, if you reset the impedance.
The exception to the pairs of valves rule is the Laney Lionheart 20, which has all four in parallel, but you still can't remove two valves because it's also cathode biased with a single resistor.
No - most amps with two valves are push-pull, so if you remove one valve you will only get roughly half the waveform, which will sound oddly distorted and not very good. You need more than one *pair* of valves, so it's really limited to 4/6/8-valve amps.
Does that help at all?
I actually understood all of this, which suprised me more than anyone. A year ago I'd have been "durr..."
Great info, cheers!
DO NOT try this with a Blackstar 100 watter, the heaters are in series!
Dave.
No harm will be done, it just won't work at all...
Which is exactly what happens with a conventional stand by switch! But, you don't leave an amp in S/B all the time.
In any event, cathode poisoning is not really a problem in conventional valves, more affected CRTs according to Morgan Jones?
Dave.
It doesn’t mean they sound bad of course, but proper audio electronics design and good-sounding guitar amps are very uncomfortable bedfellows, pretty much by definition!
Not sure. I’ve also heard it used as an argument against standby switches too...
Oh! it has but not by me (despite what you know of my stance on the things!) . Cathode poisoning, as I understand it, affects valves that run with zero or almost zero anode (beam in the case of CRTs) current for very long periods of time. At a gig and amp might be put on standby for 20mins for a P and beer break? If it is not going to be used for much longer, turn the fekker off!
Dave.
A friend recently bought one from a fretboard member and likes the tone but even at the 20 watt setting might be too loud for home use.
The Jaz 20/40 has 'the front end of the MAZ series coupled to a cathode biased 4 6V6 output section'
From @ICBM 's comments above I think the answer is yes as long as each valve has a separate resistor.
Any advice that will prevent blowing the amp up will be gratefully received
You can't pull one of the remaining valves because it's both half of a push-pull and also shares a resistor.
20W will be *way* too loud for home use if you want to crank it up, and so would 10W be even if you could get that. You need an attenuator.
Would it be possible to bias the Dr Z for 6G6 or 6K6?
Thanks again
http://www.r-type.org/exhib/aaa0141.htm
http://www.r-type.org/exhib/zaa0067.htm
http://www.r-type.org/exhib/aas0031.htm
What model of Victoria is it?
The Victoria is a Regal II which is designed for valve swapping and sounds great with the 6G6s installed
Don’t try it with the Dr.Z, it will very likely fry the valves.
