Hi Everyone,
Please could I ask for help with the best way to connect my Roland AC-60 to the desk? There seems to be several options: 1. Single XLR to a single channel.
2. Double (2 seperate) XLR to twin channels. 3. Mono jack to jack.
4. Mono jack to single XLR.
5. Balanced (stereo) “DI Out” jack to single stereo jack.
6. Balanced (stereo) “DI Out” jack to single XLR.
7. Balanced (stereo) “DI Out” jack to double/split XLR.
I know that (in theory) they should all “work” but which is the best option? Note: I also run the amp into a 10” Tanglewood subwoofer but I’m guessing that this shouldn’t make any difference to this issue. Any help would be greatly appreciated. Pic of rear panel in link below for reference.
Google Image Result for https://www.gearank.com/sites/default/files/Roland-AC-60-rear-pannel.jpg
I would use Dual XLR on the amp side if you ever want to use the Tuner Output.
The DI Out signal is pre-EQ as far as I can tell from the manual, so unless the soundman wants that in order to EQ it himself, that's probably not the best option.
