Wah better with batteries?
joetelejoetele Frets: 951
I'm sure we've all seen/heard the rumours - do Wah pedals sound better with 9V batteries? Would this kind of thing even be relevant with a modern wah like a Boss PW-3?
MUSIC: Pale Blurs
  • Didn't they used to maintain all pedals were better with batteries?
    I had a Rocktek Chorus and I was for ever buying batteries. I just bung an adapter in them now
    Cheap as chips experiment :)  No idea about the Boss but "in general" wahs don't use much juice.
  • prowlaprowla Frets: 4923
    A lot of lesser power supplies do not provide a steady output, but batteries do.
    Whether you can tell the difference is something you could try out.
    There was a fashion for battery powered hi-fi amps at one stage too.
  • ICBMICBM Frets: 72345
    The difference is with vintage-type wahs which can be sensitive to the power supply, like (but to a lesser extent than) fuzz pedals, because the power supply's internal resistance is effectively part of the circuit and a higher one (like a battery) will make enough of a difference to change the sound.
    A more modern pedal like the Boss will almost certainly not be affected in any way.
  • joetelejoetele Frets: 951
    @ICBM wins it - is there anything he doesn't know?? Confirmed my suspicions - more applicable to vintage and less likely to be a factor with the Boss.
    Cheers everyone!
    MUSIC: Pale Blurs
