Helix Friedman v real Friedman, same IR - can you tell which is which? Clip within
RandomGeckoRandomGecko Frets: 319
edited October 2018 in Amps
So I've been running my Helix 4CM with my Friendman Runt, running some of the preamps through the FX return as well as using the Friedman straight up. Very versatile setup.
Decided today to compare the BE100 model (Placater) in the Helix to the BE channel on the Runt, with very interesting results. Basically what prompted this was comparing the Helix to the AX8 (as I posted yesterday, I think the Helix is the equal of the AX8, after years of thinking that the AX8 was far superior)
Anyway, I set it up 4CM with my amp and ran them both through the same IR, an Ownhammer 4x12 with a Greenback, mic'd with an SM57. In the clip, I A/B between them, using a looper to play the same clip through both the Runt preamp and Helix model of the BE.
Love to hear what people think.
  • RolandRoland Frets: 8731
    I’d love to listen, but there’s no Soundcloud link, just the logo.
  • Paste the link and remove the space!
  • relic245relic245 Frets: 962
    Sound the same to me....
  • TTBZTTBZ Frets: 2909
    Yep sounds the same to me too!
  • Sounds great but try and compare it without using the friedman power amp section for a true comparison the power amp makes up a fair bit of the friedman tone as well and how do you feel about the dynamics are they equal does it feel the same under the fingers to play? Ta
  • NelsonPNelsonP Frets: 3400
    I listened on the crappy internal speaker on my phone. On that the second one sounded better.
    Need to listen on a proper monitor.
  • MentalSharpsMentalSharps Frets: 165
    edited October 2018
    They're very similar, only a slight difference between them. I'm not familiar with what a Friedman should sound like, or what Helix sounds like, so I can't say which is which.
    It's probably just personal taste, or crappy ears, but neither sounds like what I would have guessed a Friedman tube amp would sound like, there's something that feels missing to me, like a lack of fullness. How did you dial them in, which one did you match to the other?
    The second riff (the one that is cut short) stands out as sounding different to me than all the others.
  • p90foolp90fool Frets: 31631
    I'm just getting some random acoustic song on SoundCloud.
  • digitalscreamdigitalscream Frets: 26665
    edited October 2018
    See if this works:
    http://soundcloud.com/adam-bourne-1/be-v-helix/s-8Pgkm
    For what it's worth...the second one is slightly more compressed, but I can only tell that from looking at the waveforms. On my Tannoy Reveal monitors, I couldn't tell the difference at all.
    I'd hazard a guess that the second clip in each is the Helix on that basis, but frankly...they both sound equally great.
    <space for hire>
  • ICBMICBM Frets: 72493
    The first one in each pair sounds noticeably better to me - it's fuller and more dynamic. It becomes more obvious if you listen at higher volume.
    Close enough that I doubt you would be able to tell the difference in a mix though, and I'm still not certain which is which.
  • DominicDominic Frets: 16115
    very hard to tell but I think the second is Helix
    Very close, but I slightly preferred the second one. I think running through the same IR is a great leveller tbh - you'd be hard pushed to get such close results comparing a full guitar rig with a Helix/FRFR setup, but it's impressive nonetheless.
    Very fair, however, they switch in order...
    Well that does confuse things! I listened again and I still think the first take in each pair sounds better. The second clip has the biggest difference I think. So that presumably means there is really no practical difference at all.
    edited October 2018
    Do they switch in order throughout? I still feel that only the 2nd clip is noticeably different and lacking in mids, and the rest all sound too close to notice differences.
    My guess is: Friedman / Helix / Helix / Friedman / Helix / Friedman, based on a tiny difference in attack that I am probably imagining hearing after listening to it 10 times straight
    I'm not familiar with Helix or know what 4CM is - Is the Runt's power section being used in both examples, or neither because it comes back to the Helix for power amp modelling and then to the IR?
  • octatonicoctatonic Frets: 33806
    Which Runt- 20 or 50?
  • TenebrousTenebrous Frets: 1332
    I prefer first/first/second (although the last one is very marginal). No idea which is the Helix & which is the amp - I'm just basing it one what I prefer tonally.
  • grungebobgrungebob Frets: 3339
    No idea but in every occurrence I prefer the second sample
  • Any update on this @RandomGecko ? Would be interested to know the actual results for curiosity sake.
