So, those that have loop/switcher pedals, how do you find them?
I'm really tempted by one, however I'm not sure how much I'd gain. I currently use a few pedals in front of my amp, and a few in the FX loop. As such, I'm looking at units like the
https://www.thomann.de/gb/harley_benton_fxl8_pro.htm and it's Joyo brother, which have more than one "loop" within the unit.
My current set up is Guitar -> (Occasionally Wah) -> TS mini -> Phaser -> Tuner -> Amp FX Loop Send -> Boost -> Chorus -> Delay -> Verb -> FX loop return.
So, from a numbers point of view, I'm good for each pedal to have it's own loop. Can anyone convince me (and it probably won't take much) that apart from the odd bit of post-solo tap dancing, there's loads to gain?
Cheers!
Switchers only have a point if they solve a problem. What problem are you trying to solve?
For what I want, it's fine, although it is basic. I got it because I didn't have posh needs, don't use midi, but did want the triggers so I could channel switch the amp and turn the amp reverb on/off. Once you get the hang of it, it's very easy to program, so much so that I quite often end up making new patches on the fly in some situations, and no-one notices because they're all too busy arguing about something else.
But ... even something slim like the JoYo is actually quite bulky when you allow for cables. So I ended up buying a bigger board. And then using it in the dual loop format (so you can do 4CM) is a PITA for access to the relevant I/O sockets, so I knocked up a couple of junction boxes to present all of the I/O on the edges of the board. And then your patch leads are all the wrong size/type so you buy a load more to cable it up. And then at the end of all of it you realise that 80% of the time you're using it to switch from clean with delay to dirty without, or clean without to dirty with, and actually, frankly, you could have done that with two quick taps. However, for the 20% where you going from comp + chorus + flanger + phaser + delay to overdrive + amp reverb it's rather handy.
Personally, like Howard, if I was starting from scratch I'd just get one of the decent multi-FX/modelling units first as last, because the one thing it can't do (unless you get one with midi capability and loads of midi pedals) is have patches where the effect settings are different patch to patch. Which actually would be more useful for my situation. Also, it would work out cheaper; but, as with most things, getting to where I am now was lots of little steps, not one single expenditure.
Also, from what you've said above I'd diagnose GAS rather than need
I'm very happy with my pedal collection at the moment, and certainly does everything I'd like. I've got the odd extra pedal I occasionally throw in, but I hardly ever miss, so not sure I (currently) fancy the "drop everything and go multi-fx" route although I can definitely see the benefits.
As it stands, I think i'll wait and see if any of the suitable units come up at a decent 2nd hand price and have a play.
if you don’t need that then I wouldn’t add the extra connections that can fail along with the complications and deciding in advance which combinations of pedals you want to use.
I hate tap dancing but moved over to use an ax8 give let me do it in one switch and my board of separate pedals is very simple so I can manage without a switcher.
http://thefretboard.co.uk/discussion/137650/fs-joyo-pxl-live-8-loop-switcher-w-midi-65-posted#latest
I had a Gigrig G2 - great piece of kit, easy to use, and reliable.
I now use a Helix.
R.
Eqd Speaker Cranker clone
