Any advice for a home setup that can be played quietly but still deliver a good sound?
I live in an apartment in London and need to be conscious of neighbors when I practice. Today I was paying through my Blackstar HT1 at what I thought was a moderate level, but as you need a certain level of volume to get an ok sound, it must have been louder than thought, as the neighbours made a comment to my wife when they saw each other in the entrance. Something along the lines of “Money for Nothing was my favourite song, until I heard it 50 times today”.
I’ve looked in to setups before and thought a software with monitors might work. The other thought is something like the small Yamaha amps or the new Katana Air. But I’m open to suggestions.
Or use the clean channel and a pedal if you want an overdriven sound at lower volume than you can get a good sound with the amp's overdrive channel. I would probably choose one with at least treble and bass controls, and preferably full 3-band EQ, rather than just a tone control.
Thanks guys.
Corrected .
Just comes across as dickish and rude.
Just ask nicely to keep it down.
My manager goes to me 'are you on lunch?' if I make a quick cuppa.. he knows full well I don't get a lunch break on late shifts!
Thankfully, the THR10C does REALLY well at low volumes, and based on your situation, I'd recommend it wholeheartedly.
I might give the open backed headphones a go. I’ve only ever had closed and the only way I can discribe it, is doesn’t feel like you connected to the sound you hear somehow.
THR is of interest as the smaller speakers probably create less resonate sound. It’s a 1930’s building with all solid walls and concrete floors, so the sound transfer must be in the lower range.
I splashed out and bought a helix and a set of sennheiser hd 600's and haven't looked back.
The helix is amazing piece of kit - you can do sooo much with it. It also sounds great. And those headphones are open back and really comfortable for hours of playing (closed back I found a bit draining).
Personally I really like playing through headphones. But then I grew up making electronic music so headphones where the norm.
I'd say its very hard to have an amp in a London setting you'll never get the volume to make it fun without pissing someone off.
I use a Kemper and some comfy headphones and get an amazing sound that I use to jam along to Spotify or YouTube mostly.
I use closed back headphones so I can’t hear pick and string noise. It also means you can be in the same room as someone else and not wind them up.
Worth sticking with before you rule it out for good.
I find having the TV on helps stopping them here repetitive riffs Being heard.
I would get a 100 watt amp and play money for nothing outside her door solidly for hours so she understands never to mess with you, perhaps nail a dead animal to her door for effect
Ebay mark7777_1
