Hi everyone,
I see Thomann seems to be blowing out this tuner for ~£35. I'm in need (I think!) of an accurate (strobe?) tuner so I can set intonation etc.- should have got one ages ago but never got round to it, as usual.
Are there any known problems with this tuner? I figure I can't go too far wrong for £35, the Korg Pitchblack Plus is double that and the Turbo Tuner is triple that, even from the USA. So anything similar seems to cost a lot more (unless there's something I'm not aware of (new) which is similarly accurate and cheap, in which case let me know!)- but obviously if the Planet Waves has some fatal flaw I'm not aware of then that would put me off.
Thanks for your help,
Dave
I use a pitch black and it's fine for intonation to be honest. So no doubt this one will be even better.
Yeah I mean you might well not need ridiculous levels of accuracy, but I'm kind of scared of touching the intonation before I get a better tuner in case what I already have isn't accurate enough and if it's not then I'm up the creek )
Yeah that's possible. That's one of the reasons why I've held off so long on getting the turbo tuner, I'm kind of scared I don't need it. This one at £35 is cheap enough that even if I don't need it it's not the end of the world, and is hopefully way better than I already have.
Not when I don't have an IPad )
Thanks for the help, everyone
Yeah I've ordered it. Might be a while till it gets here, one of the other things in my order was out of stock.
