I'm getting back into recording after a long stretch of inactivity. In the past (when I had more space) I always used to play drums in manually on an electronic kit. My new music room is much smaller and I don't have space for an electronic kit. Since I started recording again I've been using EZdrummer 2, punching in drums by using my synth as a trigger and then quantising and overdubbing as necessary. It's not the most satisfying of processes, so I'm wondering how other people without access to a physical kit go about creating drum tracks? I'm also wondering if it might be worth buying a set of midi pads so at least when I'm punching in drums I can feel a bit more of a tactile sensation and use sticks! I hate using/modifying "stock grooves" in EZdrummer, not least because I like odd time signatures and becomes very tiresome. What setup are you using?
Ball ache, but best I got
I'm tempted to try out a launch pad or akai APC as my finger drumming is miles better than my actual drumming.
Once you know the vocabulary of drumming it is easier to drawn in articulations that work.
Most programmed drums are too square, lacking shuffle, groove and the small ghosts that make drums sound cool.
If you record to a metronome, it locks that tempo into the DAW track, and SD offers you the choice of previewing at recorded tempo or at DAW tempo. You can also half / double time it as well.
SO what I do is set up a drum track with SD2 on it, then set up a send to a second track which is record armed. Start the track and bring the midi loop in via the preview button at the right time, locked to DAW tempo and then match the loops to the song, recording the output on the second track.
In a way, I'm playing the drums in real time or at least using the drum software as some kind of instrument. As such, you can get better at it if you practice enough. The end result is captured as a full drum kit as you can't actually output the preview, but as it directs the sound out through the track you can capture the audio.
So it's one performance only, best get it right. The benefit is no programming required at all and it matches tempo so well that the slightly clumsy changeovers between loops give it some feel. Good results so far, sometimes it can sound a little strange (why did the drummer do that roll right then?But you know what, he really sounds like he knows what he is doing).
I used to play the drums in live on an ekit but the loop drummer is a million times better than I am. I even asked a pretty decent drummer I know to have a go and he couldn't match it.
Will check those out tonight. Rabea usually does a really good job explaining what he’s doing on his videos.
Feedback
In answer to the OP, I normally either play it in using a pad controller or start with grooves from my MIDI library and then tweak from there. I can play a bit of drums so I can normally program fairly convincing parts.
