Rolling a gloss maple fingerboard edge advice
mark123mark123 Frets: 1325
edited November 2018 in Guitar
I've just aquired a great classic vibe tele ,but the fingerboard edges are too sharp .
i want a nice played in feel
I've looked at a few methods online and generally its a stanley knife blade scraping the edges .
My worry is its a gloss neck so will it chip ? Am i better sanding ?
I know it would take twice as long if not more .
Any tips? videos? for rolling a gloss maple fingerboard edge ?
    Rolling the fingerboard edges could potentially make the sharp fret ends worse, not better.
    Are you sure you mean this:
    Fret edges can be solved with a fret dress, by a competent tech.
    Rolling the fingerboard edges will mean you need to refinish the fingerboard.
    What he said ^^
    If its a maple board, it will be finished. So would need stripping, then rolling, then respraying really.
  • John_AJohn_A Frets: 3775
    Use a tremolo arm to compress the edges rather than scrape them, you may still chip the finish though
  • jaymenonjaymenon Frets: 819
    So if you get an unfinished neck with a maple fingerboard, how would you go about rolling the edges please?
    Stanley knife?
    ..and of course apply the finish after that...
    When I looked in to this I concluded it wasn't really viable to roll the edges after it has been finished.
    That's the only reason I bought an American neck even though it cost as much as the whole Mexican Strat I put it on.
  • Sand the edges so that the paint doesn't chip. Roll the edges as you wish (scraper, screwdriver, etc etc) and then finish the raw edges with oil/Wudtone/Tru-Oil etc
  • WezVWezV Frets: 16725
    Stanley knife?
    I do a gentle scrape with fresh stanley knife or razor blade
    The blade is held very lightly to just skim the edges.  I tend to move from almost flat against fretboard to almost vertical with fretboard edge to get the rolled feel.  Moving back and firth if its for a slightly scalloped edge, or consistently in one direction  for a consistent rollover.
    Old vid I did showing the motion
