24" scale heel adjust truss rod advise
hi all
I'm going to be making a short scale neck 24" like a jag/bronco etc
 what length truss rod would one need please?
I'm attempting single way heel adjust with the anchor roughly under first fret like the original
 445mm seems right for the other 25.5" neck I'm building
 so I'm guessing it's probably 420 mm or something
also, anyone got a good (pref uk) link for a suitable one way rod?
thanks as usual
  • DanielsguitarsDanielsguitars Frets: 3291
    MLten80 said:
    hi all
    thanks as usual
    I have to make my own rods because i can't find what i want, it also depends on if you want a traditional one or a modern one
    They're curved rods on fenders so you'll need a curved maple filler strip to match it, i would just measure the length of the board and as long as the anchor is around the first fret you'll end the channel very near the end of the fretboard but you'll need to drill for the adjuster at the heel, these are a pita to make
    It's hard to explain and you'll need proper jigs to do it so the adjuster hole lines up with channel, it's also drilled at an angle because the channel is curved
    www.danielsguitars.co.uk
    (formerly customkits)
  • MLten80MLten80 Frets: 162
    edited November 2018
    cheers for the info, have a wiz
    looks like I'll have to mcgyver it & adapt one
    I forgot you need to work out the curve you need and it does falls short of the end of the board, you need to have a look at slab board construction, there's pics floating around
